Hi i'm looking to upgrade my system to an 8 core amd fx-8350 with an ASRock 990FX Extreme9. I'm stuck between these two ram kits:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226299
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226281
I'm not sure whether the tighter timing or faster speed is better for an amd system.
My rig: Cpu: AMD 8350 | Cooler: Corsair h100i with Noctua nf-f12 fans | Ram: 8gb 1600 corsair vengeance | Hard Drive: 2x 1tb wd drives in raid 1 | SSd: 128gb plextor m5p  | Motherboard: asrock extreme9  | Graphics card: amd 7850 2gb | Power Supply: ocz modular | Case: cooler master cm 690 ii          Peripherals: | Monitor: x-star 1440p | Mic: blue snowball  | Keyboard: Flashget G600  | Mouse: No name |
https://linustechtips.com/topic/4874-memory-vs-timing-for-amd-systems/
I Personally am an AMD Guru of sorts,, What do you plan on doing with Said Rig?
As far as Memory goes,, yes thare is a difference refering to "Speed" vs. "Timings",, will you see it in everyday usage of your PC?
On an AMD Platform,, Unless you plan to Transcode,Encode and Edit content,, No.
I went from 1600Mhz @ 9-9-9-24 to 1866Mhz @ 9-10-9-27 and as a Gamer and Web Surfer, i saw NO increase or Decrease in performence.
hope this Helps.
As an After thought,, the Faster the Memory,, the less of a Bottleneck it is. Timings Matter only on the Milisecond level.
I don't think it makes alot of difference wether it's and AMD or Intel processor (unless we are talking about APU's, which we are not).
I always do a little math with the speed and timings to see whats "best".
CAS/Speed = overall performance? (lower = better)
8/1600 = 0,005
10/2133 = 0,0046
The 2133 are slightly better, but honestly, you won't feel the difference. Unless you wan't the "pride" of having 2133mhz RAM, going with the cheaper ones is better.
I don't think it makes alot of difference wether it's and AMD or Intel processor (unless we are talking about APU's' date=' which we are not). I always do a little math with the speed and timings to see whats "best". CAS/Speed = overall performance? (lower = better) 8/1600 = 0,005 10/2133 = 0,0046 The 2133 are slightly better, but honestly, you won't feel the difference. Unless you wan't the "pride" of having 2133mhz RAM, going with the cheaper ones is better. [/quote']
Well put
8/1600 = 0,005
10/2133 = 0,0046
Do you think the higher speed will be better for overclocking my cpu?
Honestly, I don't believe it will make any difference for you. Only a very small difference. It's completely up to you regarding what you want. Remember that RAM speeds only makes a big difference for IGP's. Not discrete GPU's. Try taking a look at this post:
http://www.anandtech.com/show/4503/sandy-bridge-memory-scaling-choosing-the-best-ddr3/6
people who say it doesn't make a difference lack experience with AMD Modular CPUs, higher frequencies are a lot more important than timings for a bulldozer/piledriver CPU and will allow you to achieve higher clocks when overclocking .
