Recommendation: Small case for NAS
Go to solution Solved by Bazilias,
​Seems to be excellent case :), but it's End of Sale on Lian-Li website and unfortunetaly unavailable where I live. Europe/Estonia.
Antex ISK 600, CoolTek CoolBlue, Fractal Design Node 304, Cooler Master Elite 110, Lian Li PC-Q08B and Bitfenix Phenom?
Hello
Suggest smallest possible cases for my upcoming NAS build, which can fit ATX PSU, since SFX is not so easy to come by where I live.
It HAS to be able to fit at least 6 3.5" drives.
Smallest case I found myself, with these parameters, is "be quiet! Silent Base 800".
It looks very nice :) and is said to be very quiet. Since 6 7200RPM drives would make a lot of noise, it would be nice if the case was silenced.
ASUS Sabertooth X79 :: Intel Core i7-3930K @ 4.6GHz + Corsair H100i GTX :: 32GB Corsair Dominator GT CL9 DDR3 :: Gigabyte GeForce GTX680 OC 4GB :: Samsung 840 Pro 256GB (OS) :: Samsung 840 Pro 256GB (VM) :: Western Digital Black 1TB (games & buffer) :: Corsair Professional Series™ Gold AX650 650W :: Corsair Graphite 600T Special White Edition :: Plextor DVD-writer :: Logitech G15 Blue :: Razer Copperheard Blue :: Logitech F710 Gamepad :: Logitech G25 :: Saitek X52 Pro
https://linustechtips.com/topic/487240-recommendation-small-case-for-nas/
Take a look at the HP Microserver Gen8, all you need to do is add drives.
Shows it only fits 4 3.5" drives. I need at least 6.
Lian-Li PC VC650A
Thanks, man ! Lian-Li PC-Q08B it is !
Lian-Li PC-Q08B and Fractal Node 304 were only ones supporting 6x3.5" bays btw.
