Hey I'm an Australian gamer who has a CRAPPY HP pavilion but still knows how to use SFM I'm on an $800 AuD budget and I would like to know what's the best GRAPHIC CARD for it here are my current specs:
AMD FX-6300 3.5GHz 6-Core Processor (chose AMD for the cores and overclock)
ASRock 970 EXTREME4 ATX AM3+ Motherboard (Dunno just like it)
Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (cheap n cheerful)
Crucial 8GB (1 x 8GB) DDR3-1600 Memory (probs upgrade to a better bandwidth)
Corsair VS 350W ATX Power Supply(found in my local technplace thing)
So yeah what graphic card again mainly SFM and gaming like TF:GO battle field at least 60+ fps
Please make it under 290 if you can
In AUD thanks
When a man comes up to Motherboard he says "hey lady wanna do it" and she slaps him with a board (BEST JOKE 2015) (I'm new to LLT I'm sorry)
https://linustechtips.com/topic/487215-sfm-pc-help-aud/
BRUH! Change that PSU to an EVGA or SeaSonic ASAP!!
MSI R9 380 2GB: http://au.pcpartpicker.com/part/msi-video-card-r93802gd5toc
You sure a 980mhz yup is hood I could get a 1.14 cheaper but I just want to make sure?
https://linustechtips.com/topic/487215-sfm-pc-help-aud/#findComment-6539018
get Corsair Vengeance 2x4GB 1600MHz its better than 1x8GB for iGP use, and the PSU to EVGA G2 or GS / XFX Pro Gold or XXX
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/487215-sfm-pc-help-aud/#findComment-6539020
get the 4GB Version
and next time put it as Animation not SFM
https://linustechtips.com/topic/487215-sfm-pc-help-aud/#findComment-6539022
I couldn't find a 4GB version that is under $290 AUS
https://au.pcpartpicker.com/part/gigabyte-video-card-gvn75twf2oc4gi Gigabyte GeForce GTX 750 Ti 4GB Video Card that good 4gb 1.06 base clock 750 ti
Any good for smooth 60fps animating and tf2/cs:go witcher 2 battlefield 4 at 1080 at 60+fps? I could get a more expensive one
https://linustechtips.com/topic/487215-sfm-pc-help-aud/#findComment-6539067
No. Please don't get a 750ti!
https://linustechtips.com/topic/487215-sfm-pc-help-aud/#findComment-6539074
Lol. R9 380 2GB has almost triple more the pixel rate and has more shading units.
https://linustechtips.com/topic/487215-sfm-pc-help-aud/#findComment-6539076
Well right will a 960 be good or just a R9 380 2GB
https://linustechtips.com/topic/487215-sfm-pc-help-aud/#findComment-6539087
In AUD thanks
Here is my build please tell me if something is wrong thanks http://au.pcpartpicker.com/p/kbVTK8
Can that animate at 60fps and game on ultra or high at 60fps?
https://linustechtips.com/topic/487215-sfm-pc-help-aud/#findComment-6539119
https://linustechtips.com/topic/487215-sfm-pc-help-aud/#findComment-6539135
The R9 280 is better than the GTX 960, but if you can spend a little more on a R9 380 / R9 285 it will be better again.
A 2GB R9 380 / 285 will preform better than a R9 280.
https://linustechtips.com/topic/487215-sfm-pc-help-aud/#findComment-6539169
So with should get at 2gb r9 380 instead of a 4gb 280?
https://linustechtips.com/topic/487215-sfm-pc-help-aud/#findComment-6539185
