So i am building a PC for my buddy and would like to hear your opinion about it, what is overkill, what is bottlenecking and so on. The build needs to stay around the price range of the listed parts.
He already has:
- Corsair cx600m PSU
- Gigabyte gtx 950
- 16 gigs of ddr3 1600mhz :D :D :D
- 2TB HDD
my plan for the rest of the parts is:
- Intel core i5 4690k (better options?)
- Gigabyte GA-Z97P-D3
- cooler master hyper 212 evo
- SilentiumPC Gladius M35 Pure Black GD-M35 (mayby a little rare brand to the states, it has build in fan control, 2 fans and its pretty cheap in EU scheme of things)
He wan't a silent build and he still could return that GPU if needed.
https://linustechtips.com/topic/486928-build-for-a-friend/
What exact PSU is it?
Also for a quieter option get a BeQuiet! Pure Rock CPU cooler
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/486928-build-for-a-friend/#findComment-6534950
Oh yeah and he likes to play CPU intensive games!
Whatbgames exactly?
https://linustechtips.com/topic/486928-build-for-a-friend/#findComment-6534952
dump that psu
Be quiet... The CXM is not nearly ad bad as CX600 , if he keeps the 950 he will be fine though if he plans to get anything more, get something better,
https://linustechtips.com/topic/486928-build-for-a-friend/#findComment-6534997
Isn't it the same thing? All in all, stay away from the CX series.
No they are not the same thing.. If he ALREADY has a CXM not a CX he is fine. The CXM is way better then the CX, not saying it is a good PSU though as long as he does not live in an area where high temps are a big issue like 100-120 Degrees F ( like in North Carolina where my Sis lives ) it is perfectly fine temporarily.
https://linustechtips.com/topic/486928-build-for-a-friend/#findComment-6535026
He lives in Finland it is cold as fuck in here!
https://linustechtips.com/topic/486928-build-for-a-friend/#findComment-6535045
That's quite a mismatch of that CPU and GPU, th 4690k would be better suited to be paired with a 970/390.Will he be using this rig for editing?
I am pretty sure he won't, I am not an expert on CPU things, could you or someone else recommend some other preferably intel cpu for the build? I would prefer intel i5 because i think it would suite his gaming needs the best.
https://linustechtips.com/topic/486928-build-for-a-friend/#findComment-6535318
