Whats Should I Do? -=!HELP!=-
Go to solution Solved by YoloSwag,
Dude just save up.
8GB of Ram is already good for the majority of games. Even your entire rig is good!
if you want X99, you better save up instead 'coz if you haven't heard, Broadwell-E is coming out soon.
The time between now and the Broadwell-E release would be ample time for you to save up, since I'm assuming you have some funds already...
So I was looking to uprgrade my RAM:
-RipsJaws 2x4GB ----> 2x8GB (DDR3)
-GTX 970 Strix ----> GTX 980ti evga
But I wanna upgrade these items too:
-FX - 8350 Black ----> i7 - 5820k
-Sabertooth 990FX R2.0 ----> Asus X-99 Deluxe or Pro
But I know this new setup will require DDR4 and I probably won't have the money for a little bit.
What should I do?
https://linustechtips.com/topic/486720-whats-should-i-do-help/
What should I do?
Save up
8350, 8gb and 970 is a decent rig for now
Save up for a whole new rig, and sell yours to get extra cash
https://linustechtips.com/topic/486720-whats-should-i-do-help/#findComment-6531919
Save up
This ^
That's a decent rig, you should really think about upgrading when the next generation of cards/CPUs come out.
https://linustechtips.com/topic/486720-whats-should-i-do-help/#findComment-6531936
This ^
hes right. i'd do the same thing. wait till the next gen of cpu's come out. I don't really see a reason to upgrade at this point in time
https://linustechtips.com/topic/486720-whats-should-i-do-help/#findComment-6531954
Dude just save up.
You can bark like a dog, but that won't make you a dog.
You can act like someone you're not, but that won't change who you are.
Finished Crysis without a discrete GPU,15 FPS average, and a lot of heart
How I plan my builds -
For me I start with the "There's no way I'm not gonna spend $1,000 on a system."
Followed by the "Wow I need to buy the OS for a $100!?"
Then "Let's start with the 'best budget GPU' and 'best budget CPU' that actually fits what I think is my budget."
Realizing my budget is a lot less, I work my way to "I think these new games will run on a cheap ass CPU."
Then end with "The new parts launching next year is probably gonna be better and faster for the same price so I'll just buy next year."
https://linustechtips.com/topic/486720-whats-should-i-do-help/#findComment-6532060
