Need help with Mac Please
Go to solution Solved by Decon,
i have a macbook air and no CD, how do you create a bootable usb drive, i know how to do it for windows but Mac is a whole new world
any live USB all work fine; just create it like you were going to use it on a PC.  as for re-installing OS your best bet it buying a USB CD drive and using an OSX upgrade CD (assuming you have one)
What happens when you try to boot it up?
PSU Tier List | CoC
Gaming Build | FreeNAS Server
try booting using USB media and transferring the files from there.  OSX also has an OS recovery mode on boot if you hold certain keys...
Want a good game to play?  Check out Shadowrun: http://store.steampowered.com/app/300550/ (runs on literally any hardware)
another 12 core / 24 thread senpai...     (/. _ .)/     \(. _ .\)
Maybe try using the mac os x recovery partition
https://support.apple.com/en-us/HT201314
Gaming rig : i5 6600k | EVGA 1070 FTW | 16Go DDR4 HyperX Fury | Intel 600p - WD Black
Laptop : Macbook 2017
Home server : AMD A10 7700k | 2*2TB unraid array + 250GB ssd cache
What is the year and model of the Mac?  OS X Recovery started coming standard for mid-2012 models I believe.
OS X: Mid-2012 Macbook Pro 15" Intel Core i7 2.3GHz | 16GB Corsair Vengeance RAM | 1TB Seagate Hybrid HD | 500GB Samsung 840 SSD | NVidia GeForce GT 650M 512MB
Windows: Intel Core i3-4170 3.7 GHz | 8GB Crucial RAM | Asus GeForce GTX 950 Strix 2GB | 250GB Crucial SSD |  Cooler Master N200
Current Project: 2700k Intel Windows/Hackintosh Build
sounds like you may have bricked the UEFI; what is the internal storage like?  (M.2 SSD, Sata, HDD...)
the recovery mode doesnt work.
SSD SM128c
remove the drive from the laptop and plug it into your PC, laptop is basically bricked until you can get someone to repair the UEFI (sounds like you force quit/shut down when flashing a firmware update)
Can you access safe mode on boot? (CMD + S hold after power on)
when i hold cmd + S a black screen with words flash really quick then goes back into regular login
try holding CMD + S until the text appears and then let go.  If you get to a root terminal you laptop UEFI is not bricked AFAIK
I would also try booting to OS X Recovery - that would be CMD + R after turning on the computer: https://support.apple.com/en-us/HT201314
when i do that i get the time mahcine which is useless cause i never made a recovery, reinstall new OS X which is also usless cause it can't find my machine information, Get Help Online, and Disk Utilities
i can access the terminal if thats what you mean
ok you just have a corrupted OS then not a bricked UEFI BIOS.  Try re-installing OSX from CD, but before you do that remove the drive and copy any data; re-installing can delete existing files.  You could also boot from a live linux USB and mount the HDD from there to view/copy data.  Hold alt on boot and select the live USB media
