What case?
Go to solution Solved by jaffacakes,
I'm upgrading from it. That was my first computer build and now I knew what I'm doing so I'm investing in a better case.
Seems right, even though the Spec-02 is a pretty solid case.
As suggested, I'd say the NZXT S340, Fractal Design Define S, or any Corsair case at that price point.
Cheers,
The Slimy Pig.
Hi, I am buying a new case soon and are there any good ones for about 60-80 dollars and about the same size or smaller as the corsair spec 02. I need atx and mid tower.
The Spec-02 is a pretty solid case. If you are daring you could try some cheaper ones from not well known brands, you never know they could be really bad or really good.
[CPU] i5-650 [GPU] MSI GTX 750 OC [RAM] Generic 6GB [MOBO] MS-7613 [HDD] WD Blue 1TB [PSU] Silverstone Strider Essential 500W [Next build Q1 2016 http://de.pcpartpicker.com/user/Presmo/saved/ ]
Please follow your own topics.
https://linustechtips.com/topic/485347-what-case/#findComment-6507758
S340 or Define S. They're both extremely good budget mid towers.
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/485347-what-case/#findComment-6507793
Cheers,
The Slimy Pig.
https://linustechtips.com/topic/485347-what-case/#findComment-6507872
