Seasonic G650 600 Watt with gold efficiency, or Seasonic S12G-750 750 Watt
SomeGreekGuy
Title is self explanatory.
Which should I get? I am going with an i5, msi gaming 5, and a msi r9 380 4G 4gb, but I am planning on crossfiring in the future.
Code-name Nyx: R7-3800X w/ Scythe Fuma 2 Rev. B | Sapphire RX 5600XT | Gigabyte B550i Aorus Pro AX | Patriot Viper 4 Blackout | 3TB NVMe Storage| Cooler Master NR200 | Kubuntu/Windows 11 | Xiaomi Mi Curved 34" | Keebwerk Mega | Logitech G602 | Audio Technica ATH-M40X| Edifier e25 Luna
Both are overkill - get the G-series for modularity
Go with the 750W even though you probably wont need it. There is nothing worse than planning for something power intensive and finding out your JUST short
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
750w definitely for the possibility of rig expansions.  A mid-high wattage PSU made with high quality components is never a bad thing.  It will probably outlast every single piece of hardware you have except maybe your monitor.  Better to get slightly more than you need, rather than spend less now, and have to deal with potentially pulling your whole PC apart to fit the new one in when you do add more cards or upgrade.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
