I am in search for a longer Micro USB 2.0 Cable for my HTC One M8 to charge with. However, I have been looking around on monoprice and Amazon, but I can't seem to find what are the amps for the OEM cable and what the amps are for the marketplace cables. Am I safe to assume that all USB cables have the same amount of amps to charge my phone? (I hope my terminology is correct. The electrical subject is not my cup of tea.)
https://linustechtips.com/topic/483414-question-about-micro-usb-cables/
the gauge of the cable kinda defines the amount of amperage you can push through the cable. Normal cables have 28AWG. Shitty ones have 30 or 32AWG. Good cables have 26AWG, and UberBeastMaster cables have 24AWG.
Go on Aliexpress and look for some decent MicroUSB cables, I guarantee you they're all over the place. I bought a pack of 5 braided cables for about $6.
Look for gauge. If you find a thicker gauge cable, it's going to carry a higher current. I don't remember what gauge cuts off and won't carry a 1.5+A current well, but I know thinner cables can't carry that current. If you can't find gauge, just wing it. Buy it, and know the return policy.
EDIT: Ninja'd by @KemoKa :(
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
As KemoKa said get cables with larger conductors in them for the power wires like theses which have 28/24AWG:
http://www.monoprice.com/product?c_id=103&cp_id=10303&cs_id=1030307&p_id=5457&seq=1&format=2
