So i just built my computer last week and i got csgo, but i cant play it because i click on play i get a black screen then i end up going back to the steam page, i press play and then i get a message saying failed to start game app already running.
Ive tried reinstalling my drivers, csgo, and steam but it still doesn't work. I dont know what to do.....
also, im using CAM for my x61 cooler, once i close CAM i cant open it back up.
i also get lag when ii try dragging windows across my monitor.
heres my build:
i5 devils canyon
ASUS r9 390
8gb RAM
ASUS maximus hero vi
And im on windows 7 64bit.
im late to fallout 4 because of this BS...  :(  :mellow:
Edited by Glenwing
Caps lock removed from title
https://linustechtips.com/topic/483305-i-need-help-urgently/
heres my build:
i5 devils canyon
ASUS r9 390
8gb RAM
https://linustechtips.com/topic/483305-i-need-help-urgently/#findComment-6483308
Does it do this with any other games?
Sally: l Intel i5 4690k | | Corsair H55 | | Zalman z12 plus | | Hitachi 2TB HDD | | Samsung 840 Pro 128 GB | | ASRock Fatal1ty z97 Killer | | Corsair Vengeance 16 GB | | EVGA SuperNova 750 watt | | MSI 390 | | Windows 10|
https://linustechtips.com/topic/483305-i-need-help-urgently/#findComment-6483315
Have you tried opening the catalyst control center, going down to gaming, 3D app settings and making a profile for CS:GO? you can make the game start with the settings you want. don't know if it will work but worth a try.
My PC: i5 4690k===MSI GAMING 3===980TI===8GB-Corsair-Vangence-Pro-Series===H100i-GTX===EVGA G2 750W===Samsung 850evo m.2 boot drive===Samsung 250gb evo SSD===Seagate-Barracuda-1TB-HDD===NZXT-H440
https://linustechtips.com/topic/483305-i-need-help-urgently/#findComment-6483340
I dont have other games :(
Download a small free to play game, see if it does the same
https://linustechtips.com/topic/483305-i-need-help-urgently/#findComment-6483387
I may have a solution.
Right click the game in your steam libary -> Properties -> Local Files -> Browse local files -> CSGO.exe (Or something simular) -> Right click -> Properties -> Compatability -> Tick "Run this program as an administrator"
If that doesnt work
Right click the game in your steam libary -> Properties -> Local Files -> Browse local files -> CSGO.exe (Or something simular) -> Right click -> Properties -> Compatability -> Run this program in compatability mode for -> (Your operating system)
I hope this works, Have fun!
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/483305-i-need-help-urgently/#findComment-6483406
Its all good guys turns out i need a disc drive so i could install drivers through the cds that AMD includes with the card, its the GPU drivers....... i tried to do it with a usb but AMD sucks balls when it comes to this kind of stuff.
Google "AMD GPU Drivers" Should pop up, and it usually will autodetect the driver you need. If that answeres your question?
https://linustechtips.com/topic/483305-i-need-help-urgently/#findComment-6488025
Yeah, turns out its my drivers theres something going on with the online drivers so i gotta get a disk drive instead.
https://linustechtips.com/topic/483305-i-need-help-urgently/#findComment-6491568
