s340 + mobo problem
Go to solution Solved by The Official Czex,
You should be able to plug them into your MOBO headers to run them as USB 2.0.
So I have decided to get a new case. I have chosen the NZXT S340. My problem is that the case has front usb 3.0 ports. My mobo box says that is has only front usb 2.0 on it. I know I could still get the case I just wouldnt have the usb ports hooked up, but is there any way around this? This is my mobo https://ca.pcpartpicker.com/part/gigabyte-motherboard-gaf2a68hmh Any help is appreciated and my specs are in my sig if you need more info. :)
https://linustechtips.com/topic/483181-s340-mobo-problem/
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/483181-s340-mobo-problem/#findComment-6481662
