I was looking at mechanical keyboards and saw Tesoro mechanical keyboards. Are Tesoro mechanical switches any good compared to others?
CPU: AMD Ryzan 7 7800X3D ECO Mode 105W & PBO Each Core -25 Mobo: ROG Strix B650E-F Gaming WiFi   RAM: 32 GB(2x16GB) G.Skill Flare X6 EXPO @6000MHz  GPU: ASRock Phantom Gaming OC Edition AMD Radeon RX 7900 XT
Case: Lian Li O11 Air Mini  PSU: Corsair RM1000e  SSD: Team Group MP34 4TB PCIe 4 NVME & 2x SSD 2.5 1TB, Mushkin REACTOR 960GB, Patriot Torch LE 960GB  Cooling: Thermalright Phantom Spirit 120 SE (PS120SE) with ARCTIC MX-6 & 9x Thermalright TL-C12 PRO 120mm
https://linustechtips.com/topic/481890-tesoro-mechanical-switches/
I'm using the Tesoro Exaclibur Spectrum, they're using the Kailh switches. Mine are blues.
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
Tesoro use Kailh on some, and Cherry MX on some.
So of course Cherry MX is the standard good quality German made key switches. And Kaihl's are the Chinese clone copies, which don't have as good quality control, and are generally of lesser quality. However, they still of course have the mechanical goodness feel.
If it doesn't say it's Cherry MX - then it's Kailh.
