Hello guys im new here and i just got an msi 7770 for my birthday but im not really happy with its performance so i was hoping to overclock it... Does any one know how to over clock it using afterburner....Any type of help is appreciated
PS:I'm a noob with pcs so i dont know anything about overclocking.... :D :D :D
Regards,ImpureHunter
CPU:Phenom II X4 965 Black Edition / Xigmatek gaia, Mobo:Gigabyte 970A-DS3Ram:Corsair XMS3 2x2GB 1333mhz, GPU:MSI R7770 GHz Edition, PSU:Corsair CX500 500W, Case:Thermaltake Commander MS-I Snow Edition.
https://linustechtips.com/topic/4818-help-with-overclocking/
get a second 7770 then you'll be very happy i am performance of my sapphires is between a 7870 and 7950.
PRIMARY NVIDIA PC
("I'm a Fanboy of Everything")
| CPU - i5-4670K @ 4.8ghz | CPU Cooler - Antec Kühler H2O 620 | GPU(S) - BIOS MODDED Twin GTX 770 4gb (Gigabyte)-master (Zotac)-slave @ 1337/2000 (8000 Effective) | Mobo - MSI Z87 GD65 Gaming | PSU - Corsair TX850M | Ram - 8gb Gskill RipjawsX @ 1866Mhz | Monitor - Samsung 27" 550 1080p 75Hz | Keyboard - Razer Black-Widow Ultimate 2013 | Storage - 2x 1TB WD-Blacks' | Mouse - AzzA Mouse Would Say "SQUEEKSQUEEK"|
SECONDARY RADEON PC
| CPU - A10-6800K @ 4.6ghz | CPU Cooler - CM Hyper EVO 212 | GPU(S) Twin Radeon 270x 2gb @ 1115/1500 (6000 Effective) | Mobo - MSI FM2-A85XA-G65 | PSU - Logisys 750W | Ram - 8gb @ 1600mhz | Moniter - Acer 24'' 1080p 60Hz
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-56668
Not happy with performance? Sell and buy something better.
yep good idea sell something that you get for your bday i dont think you thought this through so well.
PRIMARY NVIDIA PC
SECONDARY RADEON PC
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-56670
Hello guys im new here and i just got an msi 7770 for my birthday but im not really happy with its performance so i was hoping to overclock it... Does any one know how to over clock it using afterburner....Any type of help is appreciated PS:I'm a noob with pcs so i dont know anything about overclocking.... :D :D :D Regards' date='ImpureHunter[/quote']
also what card is it msi asus sapphire ?
PRIMARY NVIDIA PC
SECONDARY RADEON PC
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-56671
I uploaded a screenshot of an example MSI Afterburner setup. What I would do is increase the 'Core Clock' by about 100 MHz, and maybe the 'Memory Clock' by 200 MHz. I would then test for stability by running some sort of GPU stress tester (maybe the one included with Afterburner). You should be looking for things like black or white dots and/or screen tearing (If you don't know what this is, then just google it). If you are getting these types of things, increase the voltage by a minuscule amount and try it again. Keep doing this until you reach the core clock that you desire with the lowest voltage possible. Having a lower voltage will increase the lifespan of your card.
If you want a guide for testing stability, you can see my Guide for Thoroughly Testing System Stability here: http://linustechtips.com/main/forum/...stem-stability
You should probably read through the whole thing, but if you are only interested in the GPU stability testing part, scroll down until you see "Step 2: GPU Stability Testing with 3DMark 11".
In this guide, I used 3D Mark 11 as an example, but there are plenty of other GPU stress testing programs out there that work just as well.
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-56708
Do i need to adjust the voltage cause i dont want to burn it......Oh btw it has no crossfire capability
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-56733
Like I said above, if you don't get artifacts on your screen (black/white spots or screen tearing), then you don't need to adjust voltage. If you don't want to adjust the voltage, I would bring the core clock down until you stop getting the artifacts.
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-56862
OK i just ran msi kombuster cause 3Dmark11 wasnt work for me.My core clock is at 1100mhz and my memory maxed out at 1300 i had no problames at all... Can it go any higher or is it fine right here.....
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-56935
Well if you are happy with the results then you can stop...or you can overvolt and push a little further.
PC 1: CPU: i5 12600k     GPU: RTX 4080     MOTHERBOARD: Asus B650M-A D4       RAM: 16x4 DDR4 3200       POWERSUPPLY: EVGA 650 G6
SSD: WD Black gen 4 x2 + Crucial MX 500 x2
KEYBOARD: Keychron K4    MOUSE: Logitech G502 SE Hero   MOUSE PAD: Goliathus control XL   MONITOR: Alienware AW3423DW + LG 25UM58 + Dell 24"  Speakers: Edifier R1280T + SVS PB1000
Laptop: M1 MacBook Pro 16
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-56953
wait i just tryed to play a game and the drivers faild 3 times i ha dto reset the setting what should i do....
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-57163
If your game crashes, then probably you have overclocked it too far and is now unstable. Try running Heaven benchmark and look for artefacts. If there are artefacts, then you would need to lower your clock speed in order to make your game more stable. Did you try reinstalling the drivers because the drivers might be corrupted. What drivers are you using?
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-57269
What card is it msi asus sapphire or reference this depends a lot on the oc you can achieve.
PRIMARY NVIDIA PC
SECONDARY RADEON PC
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-57303
I have an MSI 7770 GHs edition....
https://linustechtips.com/topic/4818-help-with-overclocking/#findComment-57652
