Steelseries Siberia elite mic problem
Go to solution Solved by Mattch23,
Make sure the mic isn't muted (wheel on left cup)
Mic light on = Muted
Light off = Un-muted
Apparently it catches a lot of people out because its the reverse of what most other headsets do.
Hello, I have a Steel Series siberia elite headset, it has been working beautifully. But today I was about to play with a mate, and to use my microphone for the first time. And it just doesn't, I have tried for hours, and I think I'm going insane. I have been fiddeling with recording devices, changed USB port, reinstalled all drivers etc.
The mic is showing in recording devices, but the sound bar doesn't move, it isn't reciving any input.
I have windows 10 by the way.
Thanks in advance.
https://linustechtips.com/topic/480874-steelseries-siberia-elite-mic-problem/
If this don't work then the wires that connects to your mic is messed up.
If death has no cost, life has no worth
The dead are gone, the living are hungry
Life is not about finding yourself, it's about creating yourself.
Jesus christ I have never felt so stupid :D I have spent hours, I have even tried fixing it from my system BIOS. I was literally going insane. Thank you sir.
