Help with Javascript and CSS graph?
Solved by Mr_KoKa,
No, fillColor is used originally to create new bar, but we modified so it's uses values from data so your code that initializes your chard should look like this:
var barChartData = { labels : ["Integritas","Optimus","Spirare","Virtus"], datasets : [ { fillColor : "rgba(220,0,0,1)", strokeColor : "rgba(0,0,0,0.8)", highlightFill: "rgba(200,200,0,0.75)", highlightStroke: "rgba(0,0,0,1)", data : [{value: 1, color: '#999'}, {value: 2, color: '#444'}] } ] }
I just noticed I ate one '{' and one apostrophe. sorry, it might be the problem.
You may want to fiddle with this lines in the second part:
highlightFill : dataset.highlightFill || dataset.fillColor, highlightStroke : dataset.highlightStroke || dataset.strokeColor
so you can control color of the bar after it's beeing highlighted, I'm not sure when it happens, but probably on mouse hover or click.
