Have you downloaded drivers: http://support.lenovo.com/us/en/products/laptops-and-netbooks/ideapad-z-series-laptops/ideapad-z470
Seems to have drivers for Windows 8 try them
https://linustechtips.com/topic/479431-wifi-adapter-not-working/#findComment-6430155
This isn't the right place to post this . It will be moved by a mod to troubleshooting. ;(
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/479431-wifi-adapter-not-working/#findComment-6430173
Sorry :( im just in a rush to find a fix
no problem man ,everyone makes mistakes .
https://linustechtips.com/topic/479431-wifi-adapter-not-working/#findComment-6430188
BTW ; have you tried downloading the drivers for the wifi adapter ? from the manufacturer website ?
https://linustechtips.com/topic/479431-wifi-adapter-not-working/#findComment-6430190
