Between the normal Minecraft and the Minecraft Win10 like i know the Win10 has cross platform stuff but i mean like in terms of content and up coming content.
And how do i make a server for the Win10 edition so i can be offline but a friend can still play.
And how the hell do i change the resolution of the Win10 version so its not a stretched triple screen mess and just normal single screen at 1920x1080
Desktop: CPU: I7-5820K GPU: 980Ti, 750Ti PhysX Mobo: MSI X99A SLI PLUS RAM: 4x4 Kingston DDR4 2400MHz OS: Win10
Storage: 250GB Samsung Evo, 3TB WD Black and Green FIRESTRIKE, Reason for dedicated PhysX Card.
Peripherals: Screen: 3x BenQ VZ2350 Mouse: Razer Naga Keyboard: Some Dell Thing Sound: Razer Tiamat, 5.1 Logitech Surround Speakers
https://linustechtips.com/topic/479315-is-there-a-difference/
The normal one is Java and will run on any desktop platform (win, mac, linux).  The Win 10 one is actually just the pocket edition ported to Windows, so it's limited that way, but at least it's C++
https://linustechtips.com/topic/479315-is-there-a-difference/#findComment-6427895
 Yeah the windows 10 edition is the cut down version. You can only go so far before the world ends.
https://linustechtips.com/topic/479315-is-there-a-difference/#findComment-6427907
No there is an Infinite setting so it never ends.
Unless the infinite setting isnt really infinite
https://linustechtips.com/topic/479315-is-there-a-difference/#findComment-6428003
Yeah i noticed the Win10 edition is missing a lot of things :/
https://linustechtips.com/topic/479315-is-there-a-difference/#findComment-6428058
