Hello there
I am majoring in film & media productions and we work on both AVID and ADOBE softwares (media composer- premiere pro- after effects- etc)
I am good in video editing but so bad in PC building so excuse my ignorance please
I planned to build this PC to help me mainly on video/audio editing with some gaming on the side:
Intel Core i7-5820K
ZOTAC GeForce GTX 980 Ti AMP! Extreme
MSI X99A SLI KRAIT EDITION
CORSAIR Vengeance LPX 16GB
Corsair Hydro Series™ H100i GTX Extreme Performance
SAMSUNG 850 EVO 2.5" 500GB
CORSAIR AX series AX760
1-will this PC be good enough AVID? is this the best I can get without going with XEON and i7-5960x processors? or should I go with XEON or i7-5960x for AVID software???
2-do I really need a workstation graphics card or the ZOTAC amp extreme will be good enough?
3- should I go with a prebuilt workstation such as the ones from dell and hp or a macpro? are they overpriced compared to their performance?
all I need is a workstation/gaming console that can handle 4k raw footage easily and compatible with both AVID & ADOBE software... please help as this build is giving me a headache everyday ( anything you guys tell me would help
https://linustechtips.com/topic/478028-general-workstation-questions/
You definitely don't NEED a workstation gpu, and the 5820k should be fine for your work.
CPU - Intel i7-4790k | CPU Cooler - Cooler Master Hyper 212 EVO | Motherboard - Gigabyte GA-Z97-HD3 (Rev 2.0) | RAM - G.Skill Ripjaws X 16GB (2x8) DDR3-1866 | Storage - Samsung 850 EVO 500GB SSD | Graphics Card - EVGA GeForce GTX 980ti SC | Case - Fractal Design Define R5 w/Window (Black) | PSU - EVGA 750W B2 | Display - Acer K272HUL | Keyboard - E-Element RGB | Mouse - Logitech g502 | Sound - Klipsch ProMedia 2.1/Fostex TH-x00/Sennheiser HD595
1. Yes
2. No you dont need workstation graphics right NOW.
3. They are overpriced. Unless your software is MAC only then build your own pc.
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
1. Yes
No work station is overpriced....
Well the ones i've seen..
which part of the question you answered :?
this part.
-snip-
-snip-
