This laptop won't boot. I tried connecting the drive to another computer as a secondary drive in an attempt to recover the data, and after very long boot and loading segments, this error pops up:
"The request failed due to a fatal device hardware error hard drive."
I'm guessing that the drive's dead, is it time to pick up another? And if so, could you recommend any drives? I'm thinking that an SSD would be more suitable, something in the price range of the Samsung 840 120GB drive (which seems like a good candidate). Anything around ~120GB will suffice.
https://linustechtips.com/topic/47795-dead-drive/
https://linustechtips.com/topic/47795-dead-drive/#findComment-634555
The performance is only ok though unless they have had a overhaul on the firmware.
https://linustechtips.com/topic/47795-dead-drive/#findComment-634569
It'll feel just as fast as any other higher tiered ssd.
https://linustechtips.com/topic/47795-dead-drive/#findComment-634581
True, but why settle for slower. It was fine in somethings, but it others it was towards the bottom of the charts. http://www.anandtech.com/show/6733/kingston-ssdnow-v300-review/5
https://linustechtips.com/topic/47795-dead-drive/#findComment-634607
It's on average smack dab above or below the Samsung 840.
https://linustechtips.com/topic/47795-dead-drive/#findComment-634611
write speeds are about 90mb/s slower than the 840 and is slower in average workloads in just about everything.
https://linustechtips.com/topic/47795-dead-drive/#findComment-634630
I have a v300 and i love it. Great SSD great speed and great price and it's kingston so they know what they're doing.
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/47795-dead-drive/#findComment-634697
