Hello so this is the build im buying. http://pcpartpicker.com/p/37wfWZ I already own the HDD & CPU. I was thinking of overclocking. Will I need anything more than the stock case fans & the cpu water cooler to overclock. Also is it easy to overclock? How do you overclock?
Reliable $550 Starter PC (http://pcpartpicker.com/p/KGgpZL) *Just waiting for someone to need help with there ram so I can make a downloadmoreram.com joke*
https://linustechtips.com/topic/477916-help-for-overclocking/
1-2 extra case fans would be nice but not necessary.  Overclocking should only be done when you fully understand what each option does.  Overclockers.net has a very informative and detailed thread on basically every K series CPU released, with indepth instructions and possible troubles you might face.  You typically OC through the UEFI BIOS.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/477916-help-for-overclocking/#findComment-6403290
