Mouse DPI + Resolution Difference
By
tismanasou
in Peripherals
in Peripherals
Solved by Schnasty,
No, but using a higher resolution requires more movement to go across the screen. I just tested it by going from 1080p to 1366x768.
you know what sir?
i am really stupid.
thought this was posted in the "esport" forum so i thought he talks about ingame sensitivity. ![]()
Sorry. :unsure:
edit: 914 DPI is your way to go btw.
kasdashd ·
1
6
Ishikudeska ·
Posted in New Builds and Planning1 -
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5
play_circle_filled
Latest From ShortCircuit:
