so I found that my 8350 CPU  has a chipset driver that is version 15.7.1 and when I look at my GPU driver it is the same 15.7.1 are they any different? or do I just have to install one? If not do I just install both of them? also do you guys know what AMDXpert Utility is for or the difference between catalyst software and latest beta driver
CPU DRIVER PIC: https://gyazo.com/ac268a80407963082395ebac05c55f3a
GPU DRIVER PIC: https://gyazo.com/7921e5ad05b468a85ab5d1c4402dfd99
Thank you.
https://linustechtips.com/topic/476106-help-with-some-driver-questions/
Kindof -points for amd for not making something like this clear, but yes they should be diffrent, those drivers are foundt on 2 diffrenr page righr? One driver page for youre cpu and one for youre gpu?
Because then i would say they should be diffrent
What graphic are you using?
                  Did I help you to fix your problem or at least did offer somewhat valuable advice? Consider giving my post a "informative" or "thumbs up".
SYSTEM 2: Modded G3 case with Gigabyte GA-G33M-S2L, Intel E8600 (O.C to 4.2GHz.), 4GB GSkill PC8500, Nvidia 8800GTS (512M), Cooling provided by Scythe Big Shrunkin, HDD 1 = OSX 10.9.5, HDD 2 = Windows 7 Pro X64. (Placed 3rd in MacMod  of the year 2012) (For info see:  http://insanelymac.com/forum/topic/285641-and-the-winner-for-macmod-of-2012-is/
LAPTOP: Inspiron 1720, Modded BIOS, X9000 Core 2 extreme OC'ed and undervolted to 3.4GHz (windows only) , 6GB DDR2 800, 8600M GT, 1920x1200 Glossy display, Sigmatel Audio, 2 Kingston HyperX 120GB drives (1 with Windows 7 x64 pro & 1 with OSX 10.9.5) X9000 Processor World Record Holder since 02/2013 on Geekbench 2 : http://browser.primatelabs.com/geekbench2/search?dir=desc&q=x9000&sort=score
