Make sure you do not have any loose contacts in the case, that could be shorting.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/474584-surge-error-with-axi760/#findComment-6369643
https://linustechtips.com/topic/474584-surge-error-with-axi760/#findComment-6369953
I really doubt that this is PSU related at all, but it always good to be safe than sorry. First thing to check is voltages on each rail and see if they are within ATX spec. You can use this as a reference, http://www.jonnyguru.com/modules.php?name=NDFAQs&op=FAQ_Question&ndfaq_id=28
If everything checks out, then it's just Asus' BIOS being flaky again. That's not uncommon for an Asus board, you can simply disable that feature in BIOS - you'll be fine with out it, as the both your PSU and MB have protection built in place already.
https://linustechtips.com/topic/474584-surge-error-with-axi760/#findComment-6384681
So I disabled surge protection in the BIOS, and now this has happened.
http://youtu.be/JHT9ZR7G-4s
https://linustechtips.com/topic/474584-surge-error-with-axi760/#findComment-6405741
Thanks for posting that video. At this point, I'd remove the AX760i and test it on its own by Power Self-test. Remove all the cables connected to the PSU then press and hold the self-test button and see if the PSU fan will kick in. The LED should turn green as well.
https://linustechtips.com/topic/474584-surge-error-with-axi760/#findComment-6425759
