NFC Tags
Go to solution Solved by blu4,
so i wrote a plain text to a card with the text "test" tho i want to remove it, how ? xD
i cannot erase the whole card since its school card for printers, and i would like to not go to IT again.. :P (i dident know the card was write able)
You can't erase a part of an NFC tag, you have to wipe the whole thing. BTW, your IT should know better to lock down the tags, lol.
Back-end developer, electronics "hacker"
https://linustechtips.com/topic/474378-nfc-tags/
FacePalm! does this stop you from using the printers?
https://linustechtips.com/topic/474378-nfc-tags/#findComment-6356490
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/474378-nfc-tags/#findComment-6356495
just try to get a new card.
I know the IT just wipes cards that doesent work and re"write" or how this nfc stuff works and the card is working again :P so in case it stops working on somthing sometime i would just need to go there. Tho iv been there a few times becouse i find flaws in the school systems.
https://linustechtips.com/topic/474378-nfc-tags/#findComment-6356509
