I am soon gonna buy a liquid cooler to overclock my fx-8370 and my r9 290 direct cu2.
I only want an 4.5-4.6ghz OC because i dont think my msi 970 gaming mobo can handle a higher OC or is it worth OC at all?
right now im stuck with the noisy stock cooler and only 2 case fans.
my budget is around 80-85euro
What should I buy and what will give we the best cooling ?
- a cm seidon 120 v2 + 4 additional fans
- a thermaltake water performer c  +  4 additional fans
- a H80 for 80euro
- maybe an used h80i GT for 75 euro
- or should i grab an air cooler + 4 addtional fans
my rig ( fx-8370@ 4.6GHz / Nepton 240m/ msi 970 gaming / 16 Gb corsair xms / antec VP700P /  aerocool xpredator x1 white / costum rgb lights / r9 290 direct cu2 / 1 TB hhd/ sandisk 128gb ssd / adata SP900 128gb )
peripherals ( steelseries apex / sharkoon fireglider black / razer goliathus / lg25ub55 )
https://linustechtips.com/topic/473467-water-cooler-chose/
H80i GT, and add better fans in a couple of months.
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/473467-water-cooler-chose/#findComment-6345389
Thanks , and if i cant get the H80i GT, What is then better?
https://linustechtips.com/topic/473467-water-cooler-chose/#findComment-6345468
Thermaltake or Nzxt x41/31
Main Rig
Plex Server WIP
https://linustechtips.com/topic/473467-water-cooler-chose/#findComment-6345501
