I have a HAF 912 that I bought off of a friend about a year ago. I want to add some stuff in and don't have enough/any screws to add anything extra at all. Can someone recommend me some black screws for mounting(like 3.5" HDD screws). I also would like some case screws for like the PSU, Sides of case, etc.
CPU: I5-7600k(5.1GHz)                                                       RAM: Corsair Vengeance LED(2x8GB @ 3200MHz/CAS-15)              Case: Cooler Master HAF 912
Cooler: Hyper 212 EVO                                                      Storage: 850 EVO 250GB - 2x(1TB WD Blue(Raid 0))                                   PSU: EVGA SuperNova 750W B2
Mobo: ASUS MAXIMUS IX HERO                                       GPU: G1 GTX 970        OS: Windows 10
https://linustechtips.com/topic/471917-screws-for-case/
I beleive, although when I search for them, some are longer lengths... which doesn't make sense if they're specifically called 6-32 screws.
https://linustechtips.com/topic/471917-screws-for-case/#findComment-6327080
PSU screws come with your powersuplly, other then that the threading should be some what standardized.
I know, I need some extra. My friend literally kept everything(drive rails, screws) and I got ****, which at the time I didn't realize what I was getting lol. I was wondering which kind which Yoshi reassured me on.
https://linustechtips.com/topic/471917-screws-for-case/#findComment-6327086
- Screw 6-32 x .25 Inches: Used in PC case cover and I/O plates
- Screw 6-32 x .15 Inches: Used to install hard drives
- Screw M3 x .25 Inches: Used to install floppy drive, CD-ROM drive and motherboard
- Screw 4-40 x .18 Inches: Used in I/O plate connector
- Metal Jackscrew Standoffs 6-32 to M3: Used in motherboard installation and pre-taped PC chassis
- Metal Jackscrew Standoffs 4-40: Used in I/O plate connector
- Case fan screw: Used to install plastic-framed cooling fans to PC chassis
- Nuts 4-40 x 6 mm: Used in joining cables
- Nuts 4-40 x 1.6 mm: Used in screw 4-40
https://linustechtips.com/topic/471917-screws-for-case/#findComment-6327109
