SSD Cloning problem
Go to solution Solved by yimello,
I used Macrium Reflect to clone hdds and ssds. Have not had nay problems.
Alright. I just got my first SSD and cloned my hard drive over to it. I got some errors when Cloning about unreadable sectors, but I ignored them. When I actually got into the cloned OS, the screen would flash and it would look like windows explorer was crashing over and over again. It would go from blank desktop to black screen, and back to desktop in a loop. I let it sit for a while, and that didn't do anything. If anything it made the flashing faster. If you guys have any idea what's going on, it would be a great help to me. Also if you have any cloning software that you'd recommend, I'd like to hear it.
Thanks,
Peter
https://linustechtips.com/topic/471519-ssd-cloning-problem/
i would try to reclone it using acronis
CPU: i5 6600k @ 4.6 ghz  Motherboard: Asus z170-a  Cooling: Corsair h80i GT GPU: EVGA GTX 970  Ram: G.Skill 2x8 gb ddr4 2400  PSU: EVGA G2 Supernova 550w  Case: Corsair 200r Storage: 250GB 850 EVO + 2x wd 1 tb drives
https://linustechtips.com/topic/471519-ssd-cloning-problem/#findComment-6322317
