so im using squarespace and im trying to get a block to follow when you scroll down the page using css. that's the code I have put but it won't work?
#yui_3_17_2_1_1445504454834_874 .summary-block {
position: fixed ;
im really new to code so its probably completely wrong
https://linustechtips.com/topic/471497-squarespace-css-help/
so your html should be something like <div class="summary-block></div>
then your css should be:
.summary-block {
position: fixed ;
i have no idea what "#yui_3_17_2_1_1445504454834_874" is
its the block id
if i just put
.summary-block {
position: fixed ;
it fixed all the summary blocks in place, but i just want one block to do it not all of them.
https://linustechtips.com/topic/471497-squarespace-css-help/#findComment-6322099
Its abit hard to help you with just like a few lines of code lol.  Well assuming "#yui_3_17_2_1_1445504454834_874"  represents ONE block you just have your code like
#yui_3_17_2_1_1445504454834_874 {
position: fixed ;
if that doesnt work just show me your html and css
https://linustechtips.com/topic/471497-squarespace-css-help/#findComment-6322130
position: fixed ;
it was be being stupid...i was using the wrong block id
https://linustechtips.com/topic/471497-squarespace-css-help/#findComment-6322472
