Hello everyone,
first of all I would like to say that if I click the link to download origin, it sends me to a download origin for PC the page doesn't excist.
(https://eaassets-a.akamaihd.net/Origin-Client-Download/origin/live/OriginThinSetup.exe)
Then I downloaded the latest version of a 3rd party website.
after installing it and launching it I receive the following window
Without a login button there isn't much more I can do.
I've tried about everything, is there anyone who could help me?
Thanks
(\__/)
(")_(") This is Bunny.
https://linustechtips.com/topic/47111-origin-installation-issue/
Well it isn't in English, that's your first problem.
Have you tried typing in your info and hitting enter? :D
i5 4670k | Sapphire 7950 | Kingston 120GB SSD | Seagate 1TB | G.Skill Ripjaw X Series 8GB
PB238Q | Steelseries Sensei | Ducky DK9087 | Qck Heavy
Build Log: http://linustechtips.com/main/topic/44902-from-imac-to-my-own-creation/
https://linustechtips.com/topic/47111-origin-installation-issue/#findComment-624139
I agree xD
It says "The email adress or password is incorrect. If you log in for the first time you have to be online. Powered by EA."
Yes I've tried xD
(\__/)
https://linustechtips.com/topic/47111-origin-installation-issue/#findComment-624152
The formatting seems messed up. Check your browsers' settings to make sure that formatting isn't disabled. It is likely using IE i think. I would personally get it from the official website to be safe: http://www.dm.origin.com/download Sourced from here: https://www.origin.com/ca/download
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/47111-origin-installation-issue/#findComment-624177
If I click Download origin for PC on both those links it give's me the dead website I gave in the OP
A friend gave me the following link to remove origin
https://help.ea.com/article/manually-uninstalling-origin
It is also unavailable on my PC so there might be something wrong with my PC or Internet. I am now booting my laptop as I type this to try it on there to narrow it down.
(\__/)
https://linustechtips.com/topic/47111-origin-installation-issue/#findComment-624186
Did you check your firewall or antivirus to make sure that these links are not blocked?
https://linustechtips.com/topic/47111-origin-installation-issue/#findComment-624214
