GTX 670 on a 500W power supply
Ethre
I just wanted to know if a GTX 670 would work on my 500W psu. The thing is that my PSU is kinda cheap, it's a Cooler Master B500, I don't have any problems with it now, because my current card takes 80W less power, but I might buy an used GTX 670 for a price of a new Gtx 750Ti here. I am not really planning on changing my PSU though. Should I just get the 670 or save like 70euro more to get a new GTX 960 that doesn't take a lot of power? The GTX 670 is similar to the 960 in performance.
Its not corsair PSU and i have an 960, iam oced to very max i think theres more but GTX 670 and 960 no need more than 500W PSU
i got an palit gtx 670 jetstream and the max load watt usage said about 188 ... so my 450w be quiet was enough ;)         but i wouldnt recommend the 670 ( too loud under load)
soon i play with a 980 ti :D
CPU i7 4790K 4,7Ghz Cooling:Corsair H100iGTX+Noctua NF-F12PWM GPU: EVGA 1080ti SC+ ACX2.0+ RAM:16GB DDR3 1866mhz Crucial Balistics Tactical Tracer Mobo:ASUS Z97-AR PSU:EVGA 750W G2 Supernova Case:Fractal Meshify C Storage:500GB Samsung 850 evo, 900GB Toshiba Game Storage SSD, 2TB Data HDD
i7 4790k Devils Canyon OC @4,6Ghz,Cooler Corsair h100i GTX, GPU EVGA 980Ti SC+ ACX 2.0+ @ stoc
http://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
670 uses about 200W so you should be fine.
