Hi guys,
So i'm ordering parts.
so this is my psu, bequiet system power model : BQT S6-SYS-UA-550W
Now i know this is enough power. i just wonder if i have enough pins for the nvidia 970.
I looked up the mo number and i think these are the right specs :
20/24 pin connection mobo
8x stat p
4x hdd p
1x fdd p
1x 12v p4 plug
1x 12v p8 plug
2x pcie cables vor nvidia sli and amd crossfire
any toughts? thanks.
https://linustechtips.com/topic/470989-need-help-with-psu-specs/
Yes, it has enough for a 970.
According to this it has 2x 6+2 pin PCIe connectors. The stock 970 uses 2x 6pin connectors and a lot of aftermarket ones use 1x 8pin and 1x 6 pin. You have enough for a 2x 8 pin card.
https://linustechtips.com/topic/470989-need-help-with-psu-specs/#findComment-6315165
