Help with RAID - Did I do it right?
Go to solution Solved by ShadowCaptain,
That sucks man! :(
no it's 2x 4TB drives, but they show up as 2x <2 TB drives in disk management. That doesn't seem right to me?
no it doenst
you could try setting up raid through intels RST software
http://www.tomshardware.com/reviews/ssd-dc-s3500-raid-performance,3613-3.html
Hello,
so I set up a RAID 1 array on the intel controller of my mobo with 2 WD RED 4TB. After getting windows 7 to boot normally again (AHCI vs RAID driver issue), I can see 2 disks in disk management, both of 1677.9GB.
Did I do it right? Shouldn't I be seeing 1 drive of +-4TB instead?
https://gyazo.com/35b85fdea955d34e35c4fd9ea3448788
Also, I have a dualboot situation going on with win7/win10. Will I be able to get into the array on win 10?
Greetings,
Stef
https://linustechtips.com/topic/470967-help-with-raid-did-i-do-it-right/
Hello,
How does it appear under "computer" on your PC?
and you are sure you selected raid 0? (dont know why you want to RAID 0 two reds?)
They don't show up there, yet, since for now they are unallocated disks.
I put them in RAID 1.
If they are in RAID 1, then you will only see a single 2TB drive
You probably mean a 4TB drive, since it's 2 WD RED 4TB.
That's the thing, there are 2 2TB drives in disk management (like shown in the screenshot I linked), not 1 4TB drive...
In order for windows to use hard drives larger than 2 terabytes the drive must be setup as a GPT disk
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
No, RAID 1 is mirrored, meaning 2TB mirrored on another 2TB drive - you only get 2TB of storage
RAID 0 =  4 TB
RAID 1 = 2TB
uh... they are 4TB drives..... are you sure you have had enough sleep? :-)
Oh :D I thought they were 2TB drives, I didnt get enough sleep and I am stuck here at work ><
That sucks man! :(
no it doenst
