WiFi ethernet switch
Solved by W-L,
I don't have a bridge. I just want to know if it works at all
I believe that is possible but it would require software to enable the ability to use the wifi in the PC and Ethernet port to fwd data to the other PC's and have it act somewhat like a router in itself. The main thing with this is that PC will always need to be on to be able to do this compared to a router setup in wireless bridge mode.
Figure 7 looks to be what you are looking for:
http://www.vicomsoft.com/learning-center/wireless-networking/
