USB not working
By
Blacidevil
in Troubleshooting
in Troubleshooting
Solved by Blacidevil,
So as it turns out after a bit of research unless you follow an extensive and annoying route of slip streaming the old usb drivers into the Windows 7 install you pretty much can't do it. You're basically SOL if you want Skylake and W7. I've had to upgrade to W10 unfortunately.
derekchan ·
Posted in New Builds and Planning4 -
5
1
5
kerriya ·
Posted in Cases and Mods8 -
octester ·
Posted in Troubleshooting7 -
DavidPatrascu ·
Posted in General Discussion9
play_circle_filled
Latest From ShortCircuit:
