Hi Guys,
i play alot of Deathrun in CS:GO and i get in 1 Minute atleast 1 Time this weird Problem(Not my Video):
I've got a i5 3750k @ 4,1ghz  and a gtx 570
I've read that cs:go is a cpu heavy game but shouldnt a i5 3750k oc'ed to 4,1 ghz be enough?
According to HDMonitor my CPU just hit a max of 80% utilization (after 1 Hour of CS:GO)
I will buy a new R9 390 next month and then my CPU will have 5x 120mm Rads to cool him and i might could overclock the CPU even more i currently get 30°C Idle with it and ~60°C was the max i ever hit with fans just at 10%
How could i fix this problem? I already set CS:GO to use just 1 CPU Core
https://linustechtips.com/topic/469214-csgo-issue/
just to test it because i saw a thread that wrote that that might help
Put it to use all 4 cores,using just one is dumb.Its like having a Titan x but limiting its power to 25 percent,dumb imo.
Do you have ssd or hdd? Something similar happened to me while doing an antivirus scan,the hdd was at 99 percent usage and the game would lag like in the video when openning and closing menus
https://linustechtips.com/topic/469214-csgo-issue/#findComment-6292950
tested it with cs:go on my ssd with cs:go on my hdd
reinstalled w10 a few days ago so i even tested it with a fresh system w/o anti virus and other shiaaat
and i ofc tested it with all cores on before
https://linustechtips.com/topic/469214-csgo-issue/#findComment-6293130
Turn on use multiple threads/cores in the options menu. That'll fix it.
sadly it doesnt even testet launch options
its not as heavy as before but i still get it and it kills me often :C
"-nojoy -console +cl_forcepreload 1 -32bit -dxlevel90 -novid -refresh 120 -tickrate128 -fps_max 128 -fps_max_menu 128 -windowed -noborder -high -language english -threads 4 -heapsize 4194304 4194304"
https://linustechtips.com/topic/469214-csgo-issue/#findComment-6315820
