under $550
OP, your choices are between the BenQ XL2730Z and the Acer XG270HU. Sadly both support Freesync and not G-Sync. The only other monitor with the specifications you're asking for is the PG278Q like Birderper recommended but it's over your maximum budget.
6600k @ 4.5 GHz | SLI reference 980Ti's | 8GB Kingston DDR4 @ 2666MHz | Asus Z170-A mobo | PG279Q Monitor
https://linustechtips.com/topic/469061-need-help/#findComment-6291247
Thank you
https://linustechtips.com/topic/469061-need-help/#findComment-6291256
