Hi, i have the 760t and want the optical drive slot to get filled, so maybe ill get a fan controller. Can you tell me how nessesary is a fan controller or what else can i fill it with? If the best option is a fan controller can you tell me a sleek $50 ish one. Thanks
Why did you post this under build logs?
Desktop: i9 11900k, 32GB DDR4, 4060 Ti 8GB 🙂
https://linustechtips.com/topic/469054-fan-controllers/#findComment-6291159
