Isn't there really any other AIO with clear tubes than the Raijintek Triton? Is it possible (=easy enough) to mod/replace an existing AIO's tubes to clear ones?
I don't see why it can't be done, you just have to make sure to fill the liquid again after replacing the tube and make sure the replaced tubes seal properly.
Guide: DSLR or Video camera?, Guide: Film/Photo makers' useful resources, Guide: Lenses, a quick primer
Nikon D4, Nikon D800E, Fuji X-E2, Canon G16, Gopro Hero 3+, iPhone 5s. Hasselblad 500C/M, Sony PXW-FS7
ICT Consultant, Photographer, Video producer, Scuba diver and underwater explorer, Nature & humanitarian documentary producer
https://linustechtips.com/topic/467357-clear-tube-aio/#findComment-6270331
most of them can't be replaced. but I believe the swiftech h220x (not sure on that), and the EKWB predator you definitely can
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/467357-clear-tube-aio/#findComment-6270336
http://www.newegg.com/Product/Product.aspx?Item=9SIA66Z29F0630
clear tubing and you can pick the color
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/467357-clear-tube-aio/#findComment-6270370
Lots of bad stories I've heard of the rajintek cracking. I would go for the EK AIO and replace the tubes.
https://linustechtips.com/topic/467357-clear-tube-aio/#findComment-6270398
Pro Tip: don't use flash when taking pictures of your build; use a longer exposure instead. Prop up your camera with something (preferably a tripod) if necessary.
if you use retarded/autistic/etc to mean stupid please gtfo
https://linustechtips.com/topic/467357-clear-tube-aio/#findComment-6270399
I have checked out h220x but the high pricetag and great performance just for clear pipes doesn't really make sense.
It's not too much more than most AIO.  the predator is 200$ i think.  I dont blame you for avoiding the Triton,  I had one for a while and it never leaked but I just was not a fan after a few months
https://linustechtips.com/topic/467357-clear-tube-aio/#findComment-6270406
It looks good and would be a perfect fit for aesthetic build, but with all the negative feedback floating around it doesn't seem like such  a good deal. I could also sacrifice some looks of the build and go something more usual like NZXT Kraken, but I don't really know..
https://linustechtips.com/topic/467357-clear-tube-aio/#findComment-6270457
I didn't realize the swiftech was so hard to get a hold of.  I think the predator is a really good option, although it costs more than the swiftech.  If I had to get an AIO it'd be the predator since it's made with actual proven watercooling parts, is actually powerful enough to expand to a gpu and another rad, and replaceable hoses/fittings.  But you almost might as well make a custom loop at that price.
Just dont do what I did... which is be indecisive and waste money as you go along the upgrade path to what you really wanted all along.  in my case it was hyper 212 evo>Triton>NH-D14>custom loop.  190$ spent BEFORE i built my 400$ loop
P.S.  not saying to build a custom loop (not saying NOT to either)  just sharing what I consider my mistakes in pc building that cost me money.  (I re-read my post and thought it sounded preachy or something)
https://linustechtips.com/topic/467357-clear-tube-aio/#findComment-6270723
