Ok after using my PC I really want to water cool, this will be my first time so I want to stick to regular bending pipes. My components are already on my profile however the spec-03 is not really optimised for water cooling but I really want to water cool in that as recently i fell in love with that case despite being limited and fairly cheap. The case like i said is limited to with really rough sketch i thought of removing the hdd bracket for a slim 240 rad and a 5.25 res/pump combo. Another slim 240 res at top with barb fittings. Im planning double res as i want to water cool my gpus. Now this rough sketch is obviously random but I want your guys suggestion like what is really good parts and if I should even bother water cooling in this cheap case. Finally its a red and black theme.
Boots n cats  ^_^
https://linustechtips.com/topic/466788-water-cooling-need-help/
240 in front 240 on top with Fractal Design Venturi Fans HP Edition
and a EK D5 Pump and a Alphacool Slim Res.
Double res is unnecessary and doing soft tubing is not worth it
Get everything from EK/Alphacool/XSPC
Nothing Else
Don't make the mistakes I did
<3
Insert   Dank   Signature   Here.
https://linustechtips.com/topic/466788-water-cooling-need-help/#findComment-6263186
Nothing Else
<3
Looks sweet, is it worth doing it to my 970s and giving it some overclock power?
Boots n cats  ^_^
https://linustechtips.com/topic/466788-water-cooling-need-help/#findComment-6264020
