Hey,
I've just built a PC with pretty old hardware - should only be a small cheap storage server (Can't even list all the parts - don't know their names). It's actually a friend's old PC, but it doesn't POST. I completely disassembled it, cleaned it, replaced the thermal compound after wiping the old one off with 96% alcohol.
When I turned on the PC, all the lights started to glow, the PSU and CPU fans started to spin, and they kept spinning, but there's no output to the display, which was hooked up to the graphics card. I'd have tried to plug the monitor directly into the motherboard if I had had the proper cable to do so.
I think the graphics card is dead, but I wanted to hear your opinon.
https://linustechtips.com/topic/466642-no-post-on-old-hardware/
It's the fact that you probably don't have the Graphics drivers for the GPU. Try to use onboard graphics and get to the desktop and install the Graphics Driver.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/466642-no-post-on-old-hardware/#findComment-6261267
Is this a joke or serious?
OP, have you tried a cmos reset?
Main Rig:-
Server:-
https://linustechtips.com/topic/466642-no-post-on-old-hardware/#findComment-6261395
Drivers mean nothing if you can't get past post. They don't load till long past post.
It's not a race to the bottom.
https://linustechtips.com/topic/466642-no-post-on-old-hardware/#findComment-6261421
