Hi, im just going to get striaght to the point.
I am looking for a 144hz/120hz monitor under £240/$340. If it could have IPS with it that would be good if not a TN that produces half decent colors. Saying this how much worse are TN panels compared to IPS because i have only ever had an IPS monitor.
Here's a few i have been looking at so if you could help me choose between these that would be good or if you can find an even better monitor within my budget then amazing!
This asus one is my favorite so far: http://www.amazon.co.uk/Asus-VG248QE-24-inch-LED-Monitor/dp/B00B19T7QC/ref=pd_cp_147_2?ie=UTF8&refRID=1PZWMWA9KKWNXV3RKSQC&dpID=41WiNKwv9vL&dpSrc=sims&preST=_AC_UL70_SR70%2C70_
http://www.box.co.uk/Benq_Xl2411Z_24_LED_3D_1080P_Gaming_Mon_1551974.html?gclid=CjwKEAjw1_KwBRDEz_WvncL4jGwSJAAEym0d2ClpUodYCovbDq-nQxHimlqA0MiSMYw1hk13CH1hnxoCZuzw_wcB
http://www.amazon.co.uk/LG-25UM57-Ultrawide-Monitor-2560x1080/dp/B010JRGIR2/ref=sr_1_1?ie=UTF8&qid=1444755911&sr=8-1&keywords=lg+ultrawide
http://www.amazon.co.uk/AOC-G2460PQU-Widescreen-Multimedia-Kensington/dp/B00C144AYK/ref=sr_1_1?ie=UTF8&qid=1444748671&sr=8-1&keywords=144hz+ips
http://www.amazon.co.uk/Acer-GN246HLBid-inch-Monitor-EcoDisplay/dp/B00IG0Z0HY/ref=sr_1_1?ie=UTF8&qid=1444749602&sr=8-1&keywords=Acer+Predator+GN246HLB
Please look on UK sites since that's where i am buying from also the "MONITOR MUST BE VESA MOUNT COMPATIBLE"
Thanks, Luke.
https://linustechtips.com/topic/466640-best-144hz-for/
No IPS panel at that price point!
I have an LG 24GM77 and I really like it.
if you need more info I can post a whole review.
http://linustechtips.com/main/topic/334934-unofficial-ltt-beginners-guide/ (by Minibois) and a few things that will make our community interaction more pleasent:
1. FOLLOW your own topics        2.Try to QUOTE people so we can read through things easier
3.Use
PCPARTPICKER.COM - easy and most importantly approved here        4.Mark your topics SOLVED if they are
Don't change a running system
https://linustechtips.com/topic/466640-best-144hz-for/#findComment-6261214
Both the Asus VG248QE and BenQ XL2411Z are excellent monitors and have great colours for a TN panel. I currently own the XL2411Z and it's a great monitor!
Ok but if you didn't have either what one would you choose between the two, if not having past experience still the BenQ?
https://linustechtips.com/topic/466640-best-144hz-for/#findComment-6261293
This looks good and fits my budget i can find on listing on amazon UK but not uk power cord but thats not a huge problem. Can this be vesa mounted?
https://linustechtips.com/topic/466640-best-144hz-for/#findComment-6261299
It comes with the regular mount attached to the vesa mount but can be detached. So yes, of course A need for the review? It'S a litle crappy but it is my first review... :P
3.Use
https://linustechtips.com/topic/466640-best-144hz-for/#findComment-6261339
I'm definitely glad I got the BenQ but I don't have any experience with the VG248QE. I know however, that the BenQ has marginally better colours but you really can't go wrong with either!
I don't like 2D games...I just couldn't get into them.. ( ͡° ͜ʖ ͡°)
https://linustechtips.com/topic/466640-best-144hz-for/#findComment-6261414
