So Christmas /Black Friday/ is around the corner again, Since I overclock (A Lot) i'll obviously need a better PSU for when the time comes a 980Ti upgrade currently this is what I have
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (Purchased For $0.00)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  (Purchased For $0.00)
Motherboard: MSI Z97 XPOWER AC EATX LGA1150 Motherboard  ($232.98 @ Newegg)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  (Purchased For $0.00)
Case: Corsair 500R White ATX Mid Tower Case  ($89.99 @ Newegg)
Case Fan: EK Vardar F4-120 77.0 CFM 120mm  Fan  ($26.54 @ Amazon)
Total: $429.04
Generated by PCPartPicker 2015-10-12 10:49 EDT-0400
I would like to keep the PSU by Corsair because this time around, I kinda want to be a bit fanboyish and everything Corsair because h100i, RAM, Case, you get the point.
I was thinking something like the RM750i or the HX 850i
What do you guys think I should get? The only restrictions I really care about are
*Its by Corsair
*80+ Gold (minimum)
*Capable of SLI
*Corsair link (Preferably)
*No higher then $170
*Location U.S
*Not CX Series. (I'm sorry I had to say it)
https://linustechtips.com/topic/465867-psu-upgrade-for-build/
But you case fans aren't Corsair fans :(
Case Corsair Air 540 CPU AMD Ryzen 5 1600 GPU EVGA GeForce GTX 1080 SC2 iCX Motherboard Asus X370-F Memory G.Skill Flare X 16GB (2x8) 2400MHz Display Asus VG248QE Storage Samsung 960 Pro 512GB - Intel 730 Series 480GB SSD - 1TB Seagate Barracuda - 1TB WD Blue OS MS X Pro Peripherals Corsair K70 RGB Rapidfire -  Razer DeathAdder 2013
Case 15.4" Mid 2012 MacBook Pro CPU Intel Core i7-3720QM GPU Nvidia GT650M Memory Crucial 16GB (2x8GB) DDR3 1600MHz Display 1680x1050 AntiGlare Display Storage 1TB 5400RPM or Intel 730 Series 480GB SSD OS OS X Yosemite (Maybe El Capitan?) - BootCamp MS X Pro Peripherals Razer Blackwidow Ultimate 2014 -  Razer DeathAdder 2013 - Mionix Naos 7000 - Logitech K120 - Razer Tartarus Keypad
https://linustechtips.com/topic/465867-psu-upgrade-for-build/#findComment-6251345
thats the only thing I'm not being extremely OCD about, since I won't be seeing my fans >.<
But we know O.o and are you telling me that when you look at your computer the little voice inside your head isn't going to say "Your case fans aren't from Corsair" and lets not forget that the air being moved through your Corsair rad, isn't being moved by Corsair fans
https://linustechtips.com/topic/465867-psu-upgrade-for-build/#findComment-6251375
ghergihsgihihgahireghiua
you broke me, I don't wanna spend 7 dollars more on SP120's D:
https://linustechtips.com/topic/465867-psu-upgrade-for-build/#findComment-6251382
EVGA P2 750W. Happy?: https://pcpartpicker.com/part/evga-power-supply-220p20750x1
And I didn't read the entire list of stuffs. :c All I can say then is AX860 or RM[Whatever]i
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/465867-psu-upgrade-for-build/#findComment-6251392
since its honestly the cheapest option and @ChasingPluto broke me....
I might do it.
I just read that quote. xD I'm pretty much going to HAVE to have noctuas pulling air through my rads when it happens...
USEFUL LINKS:
https://linustechtips.com/topic/465867-psu-upgrade-for-build/#findComment-6251404
Victory! See you say you don't want to but we all know come time to buy the upgrade parts you're going to stare at the checkout going "A few bucks for those Corsair fans isn't going to hurt...right? RIGHT?!?!?!" And many fans later you're going to hate me
https://linustechtips.com/topic/465867-psu-upgrade-for-build/#findComment-6251405
I might do it.
HEY. I didn't break anything. I just pushed...a bit...
https://linustechtips.com/topic/465867-psu-upgrade-for-build/#findComment-6251410
I really cant be bothered to have some SP's from what I've heard Corsairs fans are noisy and I really don't want to risk getting another set >.<
I CAN CONTROL MY ADDICTION OKAY?
https://linustechtips.com/topic/465867-psu-upgrade-for-build/#findComment-6251416
And I'm not a basic bitch for liking Taylor Swift. We can all dream :P
https://linustechtips.com/topic/465867-psu-upgrade-for-build/#findComment-6251431
Im just gonna switch the fan in the PSU to a corsair one to piss people off...
and then put a Corsair sticker on the side and say its a special Corsair PSU.
https://linustechtips.com/topic/465867-psu-upgrade-for-build/#findComment-6251457
scribble on the box
"CORSAIR HX1500i"
"Corsair AX9000i"
https://linustechtips.com/topic/465867-psu-upgrade-for-build/#findComment-6251491
