Ive just recently started player CS:GO again and ran into a problem when trying to play with my brother in the same house. When we start a lobby and start the game, only one of use join and the other gets a message saying the leader left and they are the new leader, and they don't join the game. I have a feeling that it has something to do with our IP's but i'm not sure.
Thanks
https://linustechtips.com/topic/465285-playing-csgo-problems/
This is both on separate accounts correct? I have played fine on the same WIFI with other people so im not sure why this is happening to you, if you could give some more details about it maybe i can help.
Different accounts, he has a laptop and i have a desktop, same internet connection, I have wired he is wireless. not sure much else I can say
https://linustechtips.com/topic/465285-playing-csgo-problems/#findComment-6254691
Might be an issue with the router.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/465285-playing-csgo-problems/#findComment-6255421
The router certainly isn't a bad router. It could be some setting that i have turned off or don't have properly set up though.
Maybe, me and my brother had the issue you're having but once we upgraded our broadband to faster download and upload and the router itself changed I can't say for certain.
Chernobyl
Kraken
https://linustechtips.com/topic/465285-playing-csgo-problems/#findComment-6255547
