Sony Vegas 13 encoding using GPU
Go to solution Solved by PlayStation 2,
Ok, IC....I just wanted to see if it makes a difference sins i am editing more videos now. What edit software would be good for using a GPU to render faster?  Vegas does not seem to detect my GPU, it just say No GPU available.
Adobe Premiere.
Its CUDA support is tried and true.
Does anyone know how to get GPU encoding to work on Vegas 13 in Windows 10 Pro 64Bit, I have the latest driver installed for my GTX 980...I hear cuda is disable in Windows 10, is that true?
THE PIT VIPER SPECS
4790k @ 4.7ghz  (EVGA CLC 360MM) | 32GB Patriot Viper Extreme @2133 mhz | Asus Z97-DELUXE Cooler Master H500M.| EVGA RTX 2080 Ti FTW3
https://linustechtips.com/topic/464474-sony-vegas-13-encoding-using-gpu/
It's not.
Either way CUDA rendering in Vegas ain't that good.
THE PIT VIPER SPECS
Adobe Premiere.
Adobe Premiere.
OK, thx....Now lets check how much it cost, prob more expensive then Vegas.
THE PIT VIPER SPECS
