Hey, ive been debating for awhile weather i need a new monitor. I have been using a old hanspree 21" 10:9 monitor, its been clicking and turining off by itself so i decided i needed a new monitor(s) i have a beastly machine rocking a intel 4790k OC to 4.75 GHz and a single Nvidia GTX 980 ti OC to a core clock of 1250Mhz. Im not a 4k fanatic, but i am very picky about bezels when it comes to multi-monitor setups. So if someone could please help me look that would be great. I have looked quite a bit and it seems i am looking for 3 monitors under these specifications.
1. 1080p only
2. Displayport connectivity (isnt a must but i could use hdmi with adapters)
3. Vesa mounts (any size is fine and its isnt a must either)
4. A 21-26" pannel
5. IPS or TN pannel
6. Refresh rate of 60hz or higher
7. Under 150$ per moniter (somewhere around here is fine)
8. Has to have VERY thin bezels or as thin as you can find (or a monitor that would have a thin frame after de-bezeling)
https://linustechtips.com/topic/464344-nv-surround-options/
