motherboard problem
Go to solution Solved by LiquidGoo,
I have a USB keyboard and my motherboard booted to quickly for the USB to initialize. I fixed it my moving my keyboard's USB connector to a different port.
So is it fixed? If it's fixed then click "Mark as solved" on the post that fixed it.
The usual keys are esc, f1, f2, f9, f10, f11, f12 or del. If you tried all of them, try with another keyboard, ps2 if possible.
Project Depravity: £850 / ????? (03/12/2015) Case: Phanteks Enthoo Primo SE Red Keyboard: Corsair K95 RGB MX Red Monitors: 3* Asus PG279Q Stand: Ergotech Triple Desk Stand Webcam: Logitch C920
RIP in kill: CPU: Single core Celeron M @1.73GHz RAM: 1GB (512MB x2) DDR2 SO-DIMM Motherboard: Asus MOCA-AR HDD: 160GB SATA2 5400rpm
Current System: CPU: Intel i5-4690K Cooler: Cooler Master Hyper 212 EVO Motherboard: MSI Z97 Gaming 5 RAM: Kingston HyperX Fury 8GB 1866MHz GPU: Gigabyte Windforce 960 4GB SSD: Sandisk Ultra Plus 128GB HDD: WD Caviar Blue 1TB PSU: Corsair CX500M Case: Corsair 200R Windowed MonitorLG 22MP55HQ 22" IPS + HP w19 MouseRoccat Savu Keyboard: Corsair Raptor K30 Mouse Pad: Perixx DX-1000XXL Headset: Kingston HyperX Cloud OS: Windows 10 Pro 64-bit
https://linustechtips.com/topic/464304-motherboard-problem/#findComment-6231792
https://linustechtips.com/topic/464304-motherboard-problem/#findComment-6231984
