I'm trying to understand that section on HWMonitor about my battery of my laptop, as it is showing 3 different values, with only one battery can anyone clear this up a little bit for me.
Laptop spec in my signature (Cosmos III) from pc specialist.
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/463750-hwmonitor-battery-section/
they are current, min, and max. for the voltage that is.
right, but what exactly is it tell me since there are three different values for all of them?
Current Build :
Laptop:
 CPU:
I think the designed is how much the battery could store when brand new, the full charge is how much it can hold in its current condition, and the current is how much is left? I think?
i would assume the same thing.
Intel Core i7-6700k | 2 X Gigabyte 4GB GTX 970 Overclocked Edition | 16GB (4X4GB) DDR4 2133MHz Corsair Dominator Platinum | MasterCase Pro 5
ASUS Z170 Deluxe Motherboard | 256GB Samsung 840 Pro + Seagate 2TB Storage | Corsair Hydro H80i GT | Windows 10 Pro 64bit | Corsair HX850i
You're right. Designed is what it is rated to hold and held brand new, full is how much charge it holds at 100% at current wear levels, and current is how much is left
LTT's fastest Valley 970, slowest Valley Basic and Extreme HD scores
Desktop || CPU - i5 4690k || Motherboard - ASUS Gryphon Z97 || RAM - 16GB Kingston HyperX 1866MHz || GPU - Gigabyte G1 GTX 970 *Cough* 3.5GB || Case - Fractal Design Define R5 || HDD - Seagate Barracuda 160GB || PSU - Corsair AX760
It's fine i was being super dumb, and forgot about the value, min and max parts of HWMonitor and forgot that it is showing all three of those and the one on the left is the numbers i should follow. Thanks for everyone's help
Current Build :
Laptop:
 CPU:
