Hi
I have three 1080p 24inch monitors, I currently have two hooked up. My graphics card is a Sapphire HD 7870 XT basically a HD 7950 with less vram, it will only allow me to run two monitors at a time....the third one will come up in windows but cannot receive any output from my PC, I can switch between any two monitors but only two will run at any given time.
Any ideas why this is happening ? can my card even run three ?
Thanks guys
Intel i5 3570K. Cooler Master Seidon 120V. Asus P8Z77-V LK. Corsair vengeance LP 8GB. EVGA GTX 980 TI ACX 2.0+ SC. Seasonic M12-II 750w. NZXT H440. Crucial BX100 250GB. Corsair Neutron 64GB SSD. Seagate 1TB. Razer Death Adder 2013. Razer Blackwidow Tournament. Beyerdynamic DT 990 PRO 250 ohm/Mod Mic 4.0. FiiO E10K DAC. Steelseries QCK+. Benq XL2430T@144Hz. 2x Dell U2414H. Phone Sony Xperia Z3
https://linustechtips.com/topic/463478-running-three-monitors/
Hi
Thanks guys
dp hub?
"God created war so that Americans would learn geography"
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6220458
It sounds like you have enough ports... Is the 3 together exceeding the maximum resolution it can drive?
But yes your card can run 3. Apparently it can run 6, according to the website.
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6220469
With any of the the cards in the 7000 series or earlier (including some 200 series rebrands) you need an active Display Port adapter to have the 3rd monitor working.
CPU: i7 5820K 4.0GHz @1.15V | MOBO: Asus X99 Sabertooth | GPU: Gigabyte Windforce GTX 980Ti, LTT Orange | CASE: NZXT H440 Black 2015 | COOLER: Noctua NH-D15S w/ LTT Fans | RAM: 32GB Patriot 3000MHz | STORAGE: 512GB Samsung 950 Pro, 960GB Sandisk Ultra II 3 x 8TB Seagate HDD's | PSU: 750W Seasonic X series, black / orange cablemod cables| Monitors: 3x Asus VX24AH's | AUDIO OUT: Microlab SOLO 8C, Sennheiser HD 650's, Audio engine D1 Amp / DAC | AUDIO IN: Blue Snowball | Keyboard: CM Storm QuickFire TK MX Green | Mouse: Logitech G900 Proteus Spectrum + RSI Extended Mouse Pad | PCPP Linkhttp://nz.pcpartpicker.com/list/hPjFd6
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6220480
Says here it can support a 4K display http://www.sapphiretech.com/page.asp?IDno=4954〈=eng
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6220493
Any idea where I could get one of those ?
Edit: Like this http://www.trademe.co.nz/computers/cables-adaptors/monitor/auction-961414707.htm ?
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6220497
GCN 1.0 cards like the 7870 XT only support up to 2 monitors via the DVI-HDMI controller. Any other monitors will have to be run via VGA or DisplayPort. If none of your monitors have VGA or DisplayPort input, you will need to use a signal converter from a VGA or DisplayPort output on your graphics card, passive adapter cables will not work.
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6220528
Thank you so much for the information! I can't find any active mini display port to DVI adapters in New Zealand....might have to get one from the states
Edit: Is this what you mean ? http://www.trademe.co.nz/computers/cables-adaptors/other/auction-958874710.htm
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6220558
You can use a full size DP to DVI converter, and a regular Mini DP to full DP cable to connect it to your GPU if you want.
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6220562
So it doesn't matter what cable combo is used as long as there is a active adapter in there somewhere ?
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6220582
It does matter, but specifically a DP-to-DP cable doesn't affect anything. Whether you plug in the converter to a DP port, or a Mini DP port through an adapter doesn't matter, because DP and Mini DP are identical other than the physical shape of the port, which doesn't affect the electrical signal.
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6220599
I am going to use this  http://www.pbtech.co.nz/index.php?z=p&p=SEVOEM8590&name=Accell-Mini-DisplayPort-1.1-to-HDMI-Active-Adapter then a HDMI to DVI cable, that should be fine right ?
Thank you so much for your help, been trying to get this working for mouths
Dropping $50 on an adapter makes me want to upgrade my GPU :P
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6220629
Yes, that should work :)
https://linustechtips.com/topic/463478-running-three-monitors/#findComment-6225919
