Hey I have been looking to upgrade a few components of my computer, one being the case and another being a new CPU cooler. I am looking into getting the corsair 110i GTX or the 100i GTX model, but I have heard that they do not fit in most cases and am wondering if this rumor is true. I am looking into downsizing from a full tower to a mid tower so size does matter and I would like to know before I buy and find out the hard way! Any and all help is welcome! Thanks
https://linustechtips.com/topic/462430-will-it-fit-need-help/
It's not about size, it's about how you use it. Support depends on the case, but you may have to mount it in the front rather than the back.
My rig: Intel Core i7-8700K OC 4.8 | NZXT Kraken X62 | ASUS Z370-F | 16 GB Trident Z RGB 3000 (2x8) | EVGA 1070 SC | EVGA SuperNova NEX650G1 | NZXT H700 | Samsung 250GB 850-EVO | 2x 2TB Seagate Barracuda HDDs
https://linustechtips.com/topic/462430-will-it-fit-need-help/#findComment-6205947
There are m-ITX cases with 360mm radiator support and atx cases that only support 120 mm no radiator. Form factor =/= Cooling support. Find a case you like and then check to see if it has support for the cooler you want.
I am conducting some polls regarding your opinion of large technology companies. I would appreciate your response.
Microsoft Apple Valve Google Facebook Oculus HTC AMD Intel Nvidia
I'm using this data to judge this site's biases so people can post in a more objective way.
https://linustechtips.com/topic/462430-will-it-fit-need-help/#findComment-6205984
