so ever since i accidentaly moved power cable in my pc and my pc shut down (at the time i was on firefox) firefox runs sites and stuff really slowly takes up to 20 seconds to load up youtube i tried internet explorer everything runs fine smooth no slowdowns or anything
now the problem with internet explorer is that videos on youtube look like they are animated so thats why i dont use it before firefox was doing fine fast and smooth... now its just tragedy and i have 94-100mbps internet connection
https://linustechtips.com/topic/462400-firefox-loading-slow-pls-help/
Make sure that nothing else is using your connection?
Have you tried reinstalling FireFox or using a different browser that's not IE, such as Chrome?
Sig under construction.
i tried chrome... crashes everytime i open it for some reason
also no ones else using my connection its wired
If you perform a speedtest.net test in FireFox do you see the speeds you just stated?
Have you tried messing with any options in FireFox?
